vcProductFeed
A product feed is an abstract object that informs Visual Components about a product that is ready for transport or the next process. vcProductFeed is the owner of a feed and has full control over the feed.
Referenced by: vcProductMatcher.PendingFeeds, vcProductNeedFeedMatch.MatchedFeed
IsCancellableBooleanRGets if the feed can be cancelled. Internal feeds cannot be cancelled.
NextProcessFlowOptionslistRGets the list of options (in priority order) to be matched to possible needs.
NextProcessGroupIdStringRGets the name of the target process.
ValueError: When feed has multiple destination processes. Use NextProcessFlowOptions instead.
ProductvcProductRGets the product instance in the simulation.
SourceNodevcTransportNodeRGets the current location of the product instance.
newvcProductFeedvcProduct product,
vcTransportNode node,
String OR None nextProcessGroupId
Creates a new vcProductFeed object and returns the new feed.
Creates new product type and assigns it to the given flow group. The name must be unique.
product (vcProduct): The product to attach the feed to.
node (vcTransportNode): The source node of the feed.
Optional: nextProcessGroupId (str): Name of the target process. If not defined, the feed can be matched with any process that has a need with the matching product and a valid transport solution, including an existing route and necessary links.
vcProductFeed: The created feed.
List[vcFeedOptionFlowInfo] options
options (List[vcFeedOptionFlowInfo]): List of options defining a flow group.
setOnMatchedNoneCallable OR None functionSets the callback function that is called when the feed is matched with a need.
function (callable): The function to call when the event is triggered.
tryCancelBooleanNoneCancels a match and removes the feed from vcProductMatcher. A match cannot be cancelled after the match has been finalized.
bool: True if the match was cancelled or the feed was not found in the product matcher. False otherwise.
ValueError: When the feed is not cancellable due to being handled internally.
